Just Pressure Washed Through my Clearcoat.....Aaarghhhh - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2011, 08:50 AM
My modern daily driver had a clear bra on the bonnet and mirrors to protect against stone chips
I didn't like the look of it so I removed it
Unfortunately, is doesn't protect against stupidity
Whislt washing the car after removal there were a couple of patches of glue still on the paint
I got these off with my pressure washer
I'm happy with my pressure washers performace......it removed some of the clearcoat too
I've been to the local body shop, and they've said it can't be repaired, blah blah.....
I know it can be repaired, can I do it myself with rattle can clear, or do I need to get a different body shop?
Old 04-20-2011, 09:16 AM
TucsonJay's Avatar
You didn't say if the bascolor might be affected. Is it clear only?
If it is, then what they could be talking about is the fact that you have some sort of adhesion problem. That means that if the whole car has that problem... the old paint needs to come off. :-(
Old 04-20-2011, 09:32 AM
The basecoat is perfect
The car is an '01 911 Turbo with original paint
I just had the pressure washer way too close (using it to remove the glue) and it took some clear coat off
They said you can't blend clearcoat into a spot repair, that there would be loads of overspray, and that it would quickly fail
Personally, I think I could mask it and rattle can it - but I've never done any painting before, so I need educating
Old 04-20-2011, 10:47 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
You can do a blend but there is the need of good skills to do it so the repair does not show. the new clear is likely to have a bit of difference in the gloss as compared to the old so the repair shows..buffing can solve the problem..find another shop that does repairs on those cars \\
Sam
Old 04-20-2011, 11:18 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
No rattle cans!
Old 04-20-2011, 11:34 AM
Thanks
I'll post some pictures later so you can see the damage
There's a circular spot on the front bumper, and quite a bit missing on the wing mirror
I don't think they're big jobs
The bumper is only a small patch, and if need be the mirror could be sanded right back
Old 04-20-2011, 01:10 PM
What they told you is correct, (Blah, blah) you can't spot clear in the middle of the hood and have it turn out and last, blah blah.
If the clear has came off and left the base coat intact, it is likely going to de-laminate because the clear isn't attached to the base properly or it woudln't have came off! blah blah.
If you spoted the clear over that it will VERY likely life with the solvent getting under the clear that isn't stuck to the basecoat! blah blah
To repair it the entire hood properly it needs to be painted (at least at the damaged spot) and the whole thing cleared at the very least. blah blah
The same with the mirror and the bumper. blah blah
Your pressure washer didn't blow off good clear, that wouldn't happen. It blew off clear that was ready to fail anyway.
So yes, it isn't a quick fix, sorry to tell you, blah blah.
Old 04-20-2011, 01:37 PM
a pressure washer can cut through paint no problem as long as its a quality unit.
with a 01 911 in the driveway i think this guy may also have a quality pressure washer.
i highly doubt there is a issue with the paint on a 01 Porsche.
i would have it fixed by a well recommended shop with plenty of references
Old 04-20-2011, 02:22 PM
Any shop doing quality work is going to clear that entire hood, PERIOD. The original poster wants to repair it with a rattle can, I doubt he would spend the money on super high pressure washer. And if he is complaining the way he did about the body shop I have to assume they told him it needs to be completely cleared which it does and he didn't want to hear it.
Without more info, is it a repaint for instance we have no idea how big it is, where it is on the hood, etc. But realistically ANY damage that needs spraying on any single panel gets the panel completely cleared, if it is being done correctly.
Old 04-20-2011, 03:26 PM
Thanks for the replies everybody
It's very much appreciated
As I said at the start, I don't know about painting
I wasn't trying to be cheap with the rattle cans, I'm just uneducated
But - we are all someone elses idiot
I may not know about painting, but I am here to learn
Thanks for taking time to reply Brian
It wasn't that I didn't want to hear what the guy at the bodyshop had to say
It was just that he had a bad attitude
He wasn't rude, but everything was too much trouble
It seemed like he wasn't interested in the work regardless of whether it were a big or a small job
The guy that does my detailing said the car has very good paint, and has never been touched (obviously can't comment on adhesion)
But I wouldnt have thought the manufacturer would take short cuts here
If it needs stripping and starting again, then so be it
It only looks minor to me - but, as stated, I don't actually know what I'm talking about when it cones to paint
With regards to my pressure washer
I own a Karcher HDS550C
It cost a little under £2,000 (English money) and it's a hot water blasting beast
The damn thing is near half the size of the car
Old 04-20-2011, 03:28 PM
willowbilly3's Avatar
Last journal entry: Body mods
I know 2 stage is the most popular paint now but I think it's weak. I have had a couple base coat/cleat coat paint jobs and it seemed very delicate. I backed my pickup up to a bank to load a 4 wheeler and it took all the paint off the edge just from the tailgate touching the dirt bank.
Old 04-20-2011, 03:41 PM
mitmaks's Avatar
Last journal entry: Grille
1. Don't pressure wash your car, hand wash it
2. Clear coat can't be reapplied to damaged base (color coat) Once clear comes off base paint needs to be sanded and another 2 coats of base need to be put on before reapplying clear coat.
Old 04-20-2011, 05:05 PM
Sorry for being such a hard ars. Bad day for me.
Old 04-20-2011, 05:11 PM
TucsonJay's Avatar
I spoke too soon. If it is factory paint, then the pressure probably just exceeded what it will stand up to.
Contact the dealership and see who does their repairs. That might be a good place to start, since they would be more familiar with how to repair that particular paint than others.
Old 04-20-2011, 07:16 PM
be thankful you didn't cut the car in half thats a big machine
Any one ever power washed the sludge out of a running engine??? Hacksaw Hotrodding Basics 19 01-14-2011 08:44 AM
Spray clearcoat over clearcoat, should I sand first? klingfilm Body - Exterior 4 10-14-2009 05:36 PM
How to fix sag in clearcoat? pszikszai Body - Exterior 7 06-28-2006 07:51 AM
washed filler areas per instructions... Skipr Body - Exterior 3 04-10-2006 12:30 PM
washed 396?? pi71 Engine 8 09-13-2005 09:42 PM
