Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - just rebuilt 4L60e locks up stall engine when place in gear
Old 03-21-2011, 08:17 PM
richard stewart 3rd's Avatar
richard stewart 3rd richard stewart 3rd is offline
Last journal entry: 351W rebuild
Hi
Are you 100% sure you have the valve body bolts in the right places? There is one longer bolt that if put in the wrong place it will protrude threw the valve body and hit the sunshell binding it.
Use a multimeter to try & figure out what the issue is.
Start with the internal wiring of the transmission, check each wire for continuity with the multimeter, check the connections ensure they are not shorting to ground or to another wire.
Rich
