Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - just rebuilt 4L60e locks up stall engine when place in gear
Old 03-21-2011, 09:07 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
The internal parts could be welded solid and not stall the engine IF the converter is operating correctly.
You have a problem in the pump or valve body.
Lock up valve with springs in the pump is a common item installed backwards by a Newbie DIY person
Is this converter a fresh rebuild or old re-used converter?
