Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - just rebuilt 4L60e locks up stall engine when place in gear
Old 03-22-2011, 07:37 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
When the trans is placed into any gear and the vehicle is not moving, no gear train parts are rotating inside the trans case.
That is why I posted the converter is the cause, unless you have an engine problem that causes the engine to stall.
If the converter clutch is applied for some reason, you put the trans into gear, the engine dies.
If the engine has problems, that may cause it to stall out when placed into gear
