just rebuilt 4L60e locks up stall engine when place in gear - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-26-2011, 09:40 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by teddybeartruck
Someone suggested that the valve may have been put in backwards. This is a common mistake for newbies like myself. In fact, that was the problem. Looking at the diagram for the pump, of the two valves one is spring in first, the other is after the valve. Apparently, glancing down at the diagram I started on one and ended up on the other, thus reversing the valve and the spring.
I have put it all back together, run the truck for about 100 miles and everything feels great.
Thanks again for all the input.
Teddybear
you are welcome.
good to hear it works for you now. It is always the simple stuff that will get you
  #17 (permalink)
Old 03-29-2011, 02:42 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Well guys, thanks again for the input. Getting enough to think about before tearing into the trans made a difference.
Good job.
Beats hell outta changing out the torque converter- to find that it didn't help!
will th350 bolt in place of 4l60e? 2manycruisers Transmission - Rearend 9 12-22-2010 09:44 AM
Stall vs. gear ratio juiced66malibu Transmission - Rearend 6 01-10-2010 02:07 PM
t-400 in place of a 4L60E in a 4x4 ? the frog Transmission - Rearend 2 08-22-2007 08:15 PM
Stall and rear gear update and thanks voodoosurfer Transmission - Rearend 1 05-06-2005 09:26 AM
Best place to buy a rebuilt 700r tranny??? bg Transmission - Rearend 3 03-15-2003 02:51 PM
