just rebuilt trans, need help - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2006, 07:26 PM
hello.first i wanna say that if it werent for a few threads on here, the trans build would have been alot harder. thank you.
any way i just rebuild a 90 700r4, 5.7 g-10 van .the rear planet blew up.
on startup i get a banging type sound. found that the flywheel or torque convertor was hitting the inspection plate.pulled that off and the noise went away BUT the flexplat/torque convertor seems to be shaking or wobbleing..
you can feel the shaking in the driver seat and visually see that its wobbleing.
Its a re-maned TC.
Could not using a pump alighnment tool cause this.i know i alighned it damn close but maybe not good enough.....
Something bent here?
i can use any help here. thank you
Old 12-09-2006, 12:27 AM
I'm not familiar with that set up, but a friend once bolted a flywheel on with it not lined up properly, and it vibrated like crazy. May be the flex plate or torque converter are not in the right position. (just My 2 cents worth)
Old 12-09-2006, 09:42 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Its a re-maned TC.
nope....... pump & stator support alignment does not cause a converter & flywheel to run with a wiggle / wobble .
Sounds like the parts need to come out for replacement.
Does the flywheel run straight with the converter unbolted?
Old 12-09-2006, 04:14 PM
thanks for the replys.
i know i used the same 3 holes, but the exact same 3 in relationship with pump engagemnt and what not im not sure of.i will rotate it and/or check with the tc and flexplate disconnected.
the pump and tc or both new/remaned units. its hard to think one of those is messed up ,but definetly possible.
I just hope its something simple like misalighnment or something.
Old 12-11-2006, 04:40 AM
well, turning it did nothing. and unbolting it and running it kinda sounds like a bad idea.
i only put about 3 qts. in the tc before installation.was that enough?
it seems to start the wobble about 3-5 minutes of running time.
im so pissed ,ill probably just take it to a trans shop.
Old 12-12-2006, 10:56 AM
just rebuilt trans,need help
Unbolting the converter ,then starting the engine,will give you lots of info.
You may be able to qualify your problem this way.
Converters that vibrate are rare,but certainly possible.
Did the thrust bearing in rear planetary let go? What other collateral damage from this failure?
Old 12-17-2006, 07:42 AM
ok, so i disconnected them and the flywheel looked bent after cranking it.so i pulled it all back out and checked the flywheel with some blocks ,a dial indicator and a granite plate.
shes out a good .090 and probably more.there was also some burrs on the flywheel to crank holes that could have been a problem. so i grabed a new one from the trans store and checked that.that ones out maybe .025 or so..
most of the wobling has gone away, i can live with whats left.witch isnt much.
anyway,the damage that i can remember done was the rear planet pinion gears were blown , 3-4 clutch was burnt. 2 holes on the spacer plate where two check balls are right next to each other, one hole was bloomed out and the checkball would go right through.i think that might have been my 1-2 shift problem.
thanks for your time guys.
trans swap laserline350 Transmission - Rearend 5 01-14-2005 10:55 PM
C4 trans ident? ptsherman Transmission - Rearend 4 12-29-2004 07:27 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
stuck drain plug on manual trans steffan_miller Transmission - Rearend 5 07-01-2004 10:15 AM
help with my 79 trans am duckhead4life Engine 2 01-14-2004 01:13 PM
