-   -   Just some friendly advice. (http://www.hotrodders.com/forum/just-some-friendly-advice-221429.html)
Chevyman87 07-08-2012 02:46 PM
I swapped my 700r4 transmission for a TH350. When installing the transmission I ran into 2 mounting issues:
1. The mounting bracket would not line up with the hole in the crossmember
2. The bolts I was using to hook up the TC to the flexplate were HARD to turn
SOLUTIONS:
To fix the mounting problem, since the placement of the trans mount was different, I made a 6"x6" metal plate (1/4" thick) and drilled 4 holes in it. 2 holes for where it would mount on the bottom of the tranny and 2 holes for where it would mount on the actual mount itself, thus making this an offset mount. To mount it, I used the same bolts that came out of the 700r4 trans mount and just bought 2 new ones along with some locking washers and nuts. I installed the old bolts to mount the plate on the transmission and the new ones with the washers and nuts to mount the trans mount on the other end of the plate. After that, everything else mouted normal.
SECOND SOLUTION:
To fix the HARD to turn bolts, use standard thread rather than the metric thread. Make sure the bolts are short as well because the bolts that came out of the 700r4 were too long, thus causing a loud rattling at cold startup that would quiet down after about 1.5 minutes of idle. Come to find out, the bolts were tightening up but were not securing the TC to the flexplate causing the loud rattle. Just make sure you get some short bolts and you'll do fine.
HOPE THIS HELPS ANYONE SWAPPING TRANSMISSIONS!!!
mmerlinn 07-08-2012 03:07 PM
SOLUTIONS:
... To mount it, I used the same bolts that came out of the 700r4 trans mount and ... I installed the old bolts to mount the plate on the transmission and ...
SECOND SOLUTION:
To fix the HARD to turn bolts, use standard thread rather than the metric thread. ...
(1) TH350 mount bolts through 1976 are AMERICAN threads. Bolts after 1976 are METRIC threads, the same as the TH700. If the TH350 case casting number starts with "6", it has AMERICAN bolts. If it starts with "8", it has METRIC bolts. The same rule applies to the speedo retaining bolt in the tail housing, unless someone had forced the wrong bolt into the hole previously.
(2) ALL TH350 converters with threaded pads through 1976 used AMERICAN bolts. SOME TH350 converters after 1976 used AMERICAN, and the rest used METRIC. TH350 converters using nuts and bolts to attach can be used either way.
