Just starting my first project (48 Chevy Coupe) - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2005, 04:27 PM
Someone did a terrible job of welding a camarro sub frame under this car. Is is possible to cut this off and replace with Mustang II. Or could I just have the welds repaired and boxed and rebuild the brakes and everything on the camarro clip?
Old 12-27-2005, 04:34 PM
Wiki Edits: 49
With the original front frame rails missing it's going to be a job trying to mount a Mustang II IFS at this point. It would probably be more cost effective to have a certified welder correct the crappy welding and just rebuild the existing Camaro sub-frame. You'll probably need to order custom wheels with the correct offset to move the tires inside the fender wells since the Camaro sub-frame is a little too wide for your car. Nova would have been better but like I said you can over come this problem with the correct backspacing on your wheels.
Old 12-27-2005, 04:54 PM
ust starting my first project (48 Chevjy Coupe)
Thank you for your advice. I think that is what i will do. Currently the wheels are inside the fenders everything looks fine from outside. It drives with no shaking or wobbling, turns and stops fine, the welding just looks unsafe and not complete. I see holes and spaces around the frame where the two were joined.
Old 12-27-2005, 05:29 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I woudl agree with what Centerline has said..Actually on a lot of these projects the bulk of the work is fixing what someone may have not done well..
OMT
Old 12-27-2005, 05:57 PM
Glennk's Avatar
first project
I went thru the same thing almost. Only I had to remove both the front and the rear. Its for sure that some people just shouldn't attempt to do some things that they know absolutely nothing about. Mine was so bad I couldn't save it and I am a certified welder. I just cut everything off and rebuilt it with 2x4 box tube and made all the suspension front and back..An awfull lot of work but for me it was worth it..As for you if you aren't a welder then what Centerline said to do would be the way to go...Good luck on your 48, they're a really neat car..Mine's a 46...If I can be of any help let me know...GlennK
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
'52 chevy coupe opinions .... coats04 Suspension - Brakes - Steering 4 12-30-2005 04:26 PM
Frame/Front End On a 48 Chevy SMF Speed&Custom Suspension - Brakes - Steering 16 12-20-2005 06:18 PM
Project 55 chevy Red434z28 Introduce Yourself 1 10-14-2005 08:29 AM
40 chevy coupe rpvette Body - Exterior 3 01-22-2003 05:02 PM
