Just a tip: for pulling wires through hose/conduit - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2012, 10:15 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
here is a tip for pulling wires through hose, conduit, or whatever
use your wire feed welder, to push some welding wire through the hose/conduit,
(by just holding the tip in the end of the hose/conduit, and pull the trigger, also turn up the wire speed and turn off gas)
then when the wire comes out the other end, stop and cut it off
attach a butt connector (with the outer covering striped off if its a tight fit) to the welding wire and the new electrical wires you want put in the hose/conduit
next use the welding wire to pull the electrical wires back through the hose/conduit
and you are done, no trying to push bendy wires like spaghetti
Old 02-01-2012, 07:03 PM
1971BB427's Avatar
I use my shop vac to suck a heavy twine through, then pull the wires with a little wire lube on them to make it easier to pull.
Old 02-02-2012, 07:40 AM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
why waste a butt connector, you already have the welder in your hand, tac the welding wire to the wire to pull
Old 02-02-2012, 08:00 AM
& matts38chev
this is used in the gas tanker industry
it is very common to use small nylon/plastic airline for conduit for marker lights etc
where one wire will barely fit in it, so you use the small mig wire
im not talking about wiring houses with 3/4"pipe conduit
give it a try, let me know how that works out for ya
Old 02-02-2012, 08:10 AM
stich626's Avatar
gearheadslife
works great..
Old 02-02-2012, 09:27 AM
Great idea!
Old 02-05-2012, 07:45 PM
1971BB427's Avatar
I do it all the time and never had any trouble sucking the line through. The vacuum just needs to have a rag around the end so no air escapes. The twine is easier to attach, and smaller than a butt splice. With a little wire lube you can get a fairly full wire(s) through without much trouble. Been using this method for over 30 years in cars, with no problems.
Old 02-05-2012, 08:52 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Nice tip Matt.
I have an oilfield fleet customer that "plumbs" all of his wiring trough synflex (nylon) air brake tubing ... including the use of the compression fittings, etc. The entire system is completely air and water-tight.
Expensive? Maybe a little bit ... but it sure helps to prevent the "green wire gremlin" from wreaking havoc.
conduit as frame stiffiners? xpsyclonex2002 Hotrodding Basics 24 11-02-2009 02:34 PM
headlight conduit earlf31 Electrical 4 09-07-2008 08:26 PM
headlamp conduit pcoghlan Electrical 2 05-09-2006 08:24 AM
Pulling new wires and loom? Jag Daddy Electrical 2 07-28-2003 12:00 AM
pulling tranny without pulling motor.... Rubberman2003 Transmission - Rearend 20 06-26-2003 09:11 PM
