2500rpm @55MPH is not high.
What cam did you install in this motor? You may need to check the accuracy of the timing tab. ( find True TDC #1 cylinder and adjust the timing tab position.) A cam that is bigger than stock with more lift and duration will need more timing at idle and will need the stock distributor advance curve modified. if you are sure of the rpm @55mph and sure you were actually going 55MPH ( GPS and or radar is nice) you can calculate the rear gear ratio once you measure the rear tire diameter. |
Why not just jack the car up, turn the rear wheels and count how many times the driveshaft turns?
Ontario Rodders |
Exactly!
a couple chalk marks on the tires and one on the drive shaft. turn both wheels equally a full turn and count how many times the chalk mark on the drive shaft comes around, thats you'r rear end gearing. I wager me left wooden leg.... 373s
Poncho62 is right you can mark the drive shaft and and rotate the tire but only if you have posi. example would be 3 and 3/4 turns would be 373 gears. You could also pull the cover (If no tag) and it should be stamped on the ring gear.
| How do you ask for help wanted? | bud34pick | Hotrodders Site Suggestions and Help | 1 | 04-28-2008 07:48 AM |
| Just wanted to say "THANKYOU" H.B.B. | Stovebolter | Hotrodders' Lounge | 0 | 01-06-2008 07:26 AM |
| rotisserie balance, hints wanted | firstgenbird | Body - Exterior | 3 | 12-10-2005 07:32 AM |
| Just wanted to introduce myself. | Marc Bitler | Introduce Yourself | 2 | 07-14-2005 06:38 AM |
| Hi just wanted to introduce myself.. | straight6nova67 | Hotrodders' Lounge | 27 | 05-06-2003 12:52 PM |
