LinkBack | Thread Tools |
You need to do more than replace the cam. All that ground up metal is now in your oil passages. It needs to be somehow cleaned out or you will be doing bearings next
Artificial Intelligence is no match for Natural Stupidity Chet |
There are many shops,ours included,that refuse to build anything but a roller engine,hydro or solid. We too have seen cam failures many miles after break-in.With oil change intervals being at 2500 miles and the added costs of a Joe Gibbs racing oil adding to that oil change each one,your ending up paying for the roller conversion alittle at a time.It doesn't seem like alot,but it adds up.All that aside from putting the engine at risk for major damages. It is true now that you have metal in the oil passages,it needs to be torn down,hot tanked,and the tolerances checked in a do-over.And do-overs almost always cost more than the roller conversion would have in the first place. |
So should I just add zinc additive every time after I do an oil change?
For a flat tappet cam and long life I recomend this stuff.
Molyslip Canada Inc. :: Molybdenum Lubricants, Performance Lubricants, Copaslip Anti-Seize, EP2 Grease, Wear Reducing Lubricants, Oil Additive This is what I use. |
Okay, until I have enough spare cash to justify throwing away the cam and lifters I just installed last night with about a grand worth of upgrades...
Should I add zinc additive after every oil change? |
Really, like I said way back, you should have torn this engine apart, inspect everything and clean it all out. That metal is all over in there and your bearings and pump will be next, and possibly the cam again.
Yeah know it does kind of tick me off some when manufactures can't be straight with people who are buying their products. Damm it,sure does make it hard for us honest folks who are just trying to help. Last edited by 1Gary; 02-22-2013 at 10:12 PM. |
For those that are very familiar with quality roller lifters vs what I imagine are ones a guy should stay away from, what brands would be suggested in ether a retro fit roller rebuild or a roller ready block. As 33Willys77 mentioned before, he had a retrofit roller adjoining bar fail and cause major damage.
Put another way, what brand of cam ( and billet or not ? ) and type of retro fit rollers should Zerocyde have used if he had decided to tear down his engine and start from scratch. |
Correction, mine were not retro fit, they were aged - rollers were good, but the connector between the lifters fatigued out. I dont know how old they were - could be from the 70's. It was not a bar, more like a peice of sprung (tin like) arched tab. Not like what they are today. I was just saying, I had a mishap and all that metal was all over the engine. I could see it in the pump and in the bearings.
Oh ok sorry, that was my mistake for visualizing a newer style retro fit unit with the link bar arrangement. As to it causing metal fragments to bypass the filter and get back into the bearings, never mind the oil pump that WILL suck in everything on the bottom of the pan and damage itself, I can see some horrible visuals of what a cam failure would cause. Thats good to know as I've had friends who did the same thing, had a cam lobe get wiped and just slipped in a new cam and lifters without tearing into the engine further and "hope" for the best. That would be like sitting on a bomb that never went off ... yet !.
| What's equivalent (power-wise) to a thumpr? | Zerocyde | Engine | 27 | 06-12-2012 11:59 AM |
| wanna increase power 1990 corvette | alinberta88 | Engine | 2 | 05-06-2009 07:42 PM |
| Wiped out a cam lobe :( | 66GMC | Engine | 25 | 04-28-2008 05:49 PM |
| Questions for wiped lobe victims & engine gurus | JPhil | Engine | 17 | 09-22-2005 07:01 PM |
| why did the cadillac 500 lose power over the years? | Macman | Engine | 15 | 07-29-2003 03:53 AM |
