Just wiped a lobe. Wanna try a non-thumpr now. Any suggestions so I don't lose power? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2013, 09:13 PM
Basically, I had the hydraulic flat tappet thumpr cam. (smallest, not mutha, etc.) Here are the specs for it.
What should I look for in a non-thumpr cam to offer close to equal power as what I have now? Just make sure it has the same lift duration?
FYI It's a 350 sbc basically stock but with upgraded aluminium heads, edelbrock air gap intake, and holley 650 dp.
Old 02-19-2013, 09:30 PM
33Willys77's Avatar
Are you saying the cam lobe wore off the cam?
Old 02-19-2013, 09:31 PM
vinniekq2's Avatar
110941-11 CL110941-11 279 279 225 225 .465 .465 111 108 Hyd. Hyd. 1
1500-5600 Fair idle, Strong mid-range performance.
or step up to
113215-10 CL113215-10 270 278 217 225 .495 .500 110 106 Hyd. Hyd. 1,2
1300-5500 Good idle, Street Performance. Strong lower mid range. Stock converter OK.
depends on money
second choice here would be nice and idle better,but make more power
Old 02-19-2013, 11:25 PM
Thats what I keep fearing although maybe unfounded but to have a wreck with a flat tappet cam rather then going the roller way. I assume you've been looking in the Comp catalog online and go to page 170 where it mentions getting a cam nitrided which will hopefully help with a cam starting the wear process and wiping a lobe. Worth asking about anyway.
Old 02-20-2013, 01:01 AM
JeffB's Avatar
Howard has been known for a harder surface core this should be a good match: Howards Cams Hydraulic Flat Tappet Camshaft and Lifter Kits CL110041-12 - SummitRacing.com
Old 02-20-2013, 01:55 AM
Yes. Noticed a ticking and saw that one rocker wasn't moving as far as the rest. Pulled the lifter out and it was beat to hell and domed. Looked down at the cam and that lob was basically gone.
Thanks for the good suggestions, guys. All I want is a cam that will (at least) match the power that I got from the thumpr, but without the whole "give up driveability for a cool sound" aspect.
Old 02-20-2013, 10:19 AM
S10xGN's Avatar
Gotta love a turbo!
It's prolly gonna be more about what oil and additives you're using than just replacing the cam. If you don't have enough zinc, ZDDP, phosphorus, etc in your oil, the new cam will meet the same fate as the current one.
Russ
Old 02-20-2013, 10:40 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Below are a couple pages w/info that should help you have a successful cam break in. If you don't read anything else, be sure to check out the first page listed. Good luck.
Cam break in
Adjusting hydraulic lifters
Valve train points to check
Valve train geometry
Valve spring installed height
Old 02-20-2013, 10:44 AM
Cam break in
I had the cam for 3 years before the lobe wiped. I thought cam break-ins were only like 200 miles...
Old 02-20-2013, 11:06 AM
vinniekq2's Avatar
why not upgrade to a small roller hydraulic like I posted?make more power with a much nicer idle
Old 02-20-2013, 11:14 AM
33Willys77's Avatar
I had a roller lifter arm break and the lifter spun and took out the roller and cam. All that metal went into the motor and chewed the bearings and pump up. Take a close look and do not just throw in a new cam. You might want to consider a rebuild!
Old 02-20-2013, 11:35 AM
F-BIRD'88's Avatar
Yada Yada Yada
Change to a Isky 270H Mega cam. Isky #201271
The idle won;t be quite as rough. Lots of power.
Be sure your lifter bores a re free of burr edges especially on the bottom edge of the bore.
The lifters must be able to spin in their bores or the cam will fail.
minor bore honing many be required.
best to pull the pan and wash everythng out after a cam lobe failure.
The Isky cams are high quality.
ISKY Racing Cams - Do It Right. Race with the Legend. Camshafts, Connecting Rods, Valve Springs, Lifters This Isky 270H mega cam is available in various versions, dual pattern, different LSA etc
I use GM EOS and this stuff
Molyslip Canada Inc. :: Molybdenum Lubricants, Performance Lubricants, Copaslip Anti-Seize, EP2 Grease, Wear Reducing Lubricants, Oil Additive E oil suplement in the oil to aid cam break in and avoid scuffing
Old 02-20-2013, 12:18 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Generally the cam is broken in for at least 20 minutes w/the engine at or above 2000 rpm, varying the rpm, w/o idling. So it's not really a matter of how many miles, unless you're able to meet the above criteria while driving the vehicle. Which isn't recommended.
The oil that is available from gas stations and parts stores is not generally going to have the additives present that are needed to keep a performance flat tappet cam and lifters from wearing at an increased rate. Using an oil specifically formulated for flat tappet performance engines, or adding ZDDPlus (or other similar additives) to OTC motor oil will help in this regard.
Old 02-20-2013, 06:13 PM
33Willys, I assume that was a retrofit style roller set then and what brand and model type were they as I know with roller cams a lot of mix and match can be done so one brand cam with another brand roller lifter and even used rollers for that matter.
Old 02-20-2013, 08:15 PM
33Willys77's Avatar
They were an old style. It was more like sprung steel in an arch that held the 2 together. One little tab broke on it and it turned. Very costly when it happens to a 392 Hemi - solid roller too.
What's equivalent (power-wise) to a thumpr? Zerocyde Engine 27 06-12-2012 11:59 AM
wanna increase power 1990 corvette alinberta88 Engine 2 05-06-2009 07:42 PM
Wiped out a cam lobe :( 66GMC Engine 25 04-28-2008 05:49 PM
Questions for wiped lobe victims & engine gurus JPhil Engine 17 09-22-2005 07:01 PM
why did the cadillac 500 lose power over the years? Macman Engine 15 07-29-2003 03:53 AM
