K-grip 392 ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2012, 08:10 AM
K-grip 392 ?
Any opinions on this adhesive ? It appears to be environmentally friendly and cleans up with water.
Old 12-27-2012, 11:05 AM
DanTwoLakes's Avatar
Wiki Edits: 22
I tried a water based adhesive called Simalfa. The problem is that the glue needs to be gravity fed for some reason, so you'll need a special gun with the cup on the top to spray it with. This one has a plastic cup and the internal parts are stainless steel, all to prevent rusting. You have to be careful that no air gets into the gun or the glue can dry inside the gun which will ruin the gun. You need to clean the gun regularly, and while it does a nice job with foam to foam applications, it will not replace top and trim contact adhesive. I was hoping it would replace both of the adhesives that I use regularly, but that wasn't the case. I'm sure it is also more expensive than regular K-Grip.
Old 01-06-2013, 05:12 PM
I take it back not from a 69 Camaro
Sorry no clue
8 3/4 sure grip rear ramman1500 Transmission - Rearend 6 03-18-2012 06:18 PM
Sure Grip or not? mitmaks Transmission - Rearend 3 07-31-2011 03:03 PM
is it a sure grip or is it not? fordsucks7 Transmission - Rearend 0 04-13-2009 06:50 PM
Bolt-grip cletis Garage - Tools 6 01-16-2006 07:43 PM
Sure-grip vibration wvrodder Transmission - Rearend 10 09-26-2002 03:43 AM
