Thanks! Thanks Top 5 Wiki Tech Article Editors! Thanks!
Updated 11/07/08
#1
Alittle1
169 edits
#2
Crashfarmer
161 edits
#3
Powerrodsmike
125 edits
#4
Techinspector1
112 edits
#5
Oldguy829
85 edits
Read and write hotrodding how-to articles on the Crankshaft Coalition Wiki. See 100+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > Hotrodding Basics
  #1
Old 12-12-2006, 09:01 PM
Marty S. Marty S. is offline
k member or x member?
I have a 2x3 tube frame for my Model T coupe. Do I need a k member , x member or just a transmission support cross member?
Old 12-12-2006, 09:13 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
re: k member or x member?
Just a trans crossmember is traditional, but a K member ads a ton of torsional strength.
Old 12-12-2006, 09:19 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Gassers were best!
Try to get a triangle or three into your design. X-member would be great but K is nice second choice. Saving grace is Ts are so light and square tubing frames are so rigid to begin with, a few robust and well installed straight X-members will do just fine.
Old 12-12-2006, 11:52 PM
pasadenahotrod pasadenahotrod is offline
T Coupe, 23-25, 26-27, 17-22, hiboy, full-fendered with boards and aprons???So many specifics, so little information.
4cyl.automatic, V6, V8, 4speed, 3speed, PowerGlide, small block, big block, ??
9", 8', 10-bolt, 12-bolt, Jag IRS, 'Vette IRS, 55-64 Chevy rear, coil-overs, coil springs, buggy spring, dual springs???
The traditional ladder style frame is fine for most T applications due to limited frame dimensions and space availability.
Old 12-14-2006, 07:34 PM
more info
I have a 2x3 tube frame for my Model T coupe. Do I need a k member , x member or just a transmission support cross member? 350 chev-700r4-rear coil over rear with 9 inch-front leaf with 4 inch drop tube axle-no fenders
Old 12-14-2006, 11:46 PM
A transmission crossmember should do you just fine. If you have the typical kickup at the rear over the rearend and tubular front crossmember like a bucket that'll do the job.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "k member or x member?"
9" ford 3rd member strength? 68c10owner Transmission - Rearend 10 06-13-2007 09:45 AM
New member alwalker Introduce Yourself 2 07-26-2006 09:43 PM
55 chevy cross member ???? tiresmoke55 Transmission - Rearend 9 04-15-2006 07:20 PM
New member to HOT RODDERS! Jeff Nix Introduce Yourself 1 07-24-2004 10:43 PM
member or jr. member??? WoodsEdge Hotrodders' Lounge 10 05-23-2002 06:30 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
