K Spray? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2010, 04:06 PM
K Spray?
Im ordering it and would like to know what to use in order to clean up with? Will regular solvent work such as lacquer thinner?
Old 06-07-2010, 08:42 PM
That is a little harsh. I use prepsol (wax and grease remover)
Old 06-07-2010, 11:45 PM
DanTwoLakes's Avatar
Wiki Edits: 22
You have to use the correct solvent or it simply won't work. K-Spray comes off with mineral spirits or Xylol, just like contact adhesive. Xylol is more expensive, but it works better.
Old 06-16-2010, 12:15 PM
The K Spray arrived. When I opened the box from Perfect Fit I thought the can was going to explode because it was bulging on the bottom. I pried the cap insert out and it went flying from the pressure.
How long should I let it dry before I attach everything together?
Old 06-16-2010, 12:33 PM
Wiki Edits: 22
When I get a can like that I puncture the liner with a punch and remove the punch very slowly to let the pressure release.
K-Spay doesn't have to be completely dry before you mate the pieces together, it can still be a little wet. Basically, when you put the pieces together and they grab one another it's ready. Try some scrap pieces first before you do the gluing for your project.
Metal Spray information incthermion Body - Exterior 0 11-17-2008 01:30 AM
Not Another Spray Gun Question! Workingwoods Body - Exterior 11 07-17-2008 02:07 PM
low priced spray gun/detail gun for primer/base/clear and ghost flames jrmy_1 Body - Exterior 15 06-08-2008 06:38 AM
Disposable Liners for Spray Guns starquest Body - Exterior 2 07-21-2006 08:12 PM
I'm good with a spray can.... what am i doing wrong! harrington Body - Exterior 21 04-25-2004 01:28 PM
