K Spray And HVLP Gun? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2010, 02:45 PM
Today I cut my foam and got ready to spray the K Spray with an HVLP gun using a 1.6m nozzle. The 1.6 mm is the largest available for this unit. The glue was drying up at the nozzle while I was spraying. Is this the result of the warm air produced from the turbine? iIt made it difficult to spay. Would u be better of with a conventional gun?
Old 07-09-2010, 07:24 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Yes, the K-Spray is thin enough to spray with a 1.6MM nozzle. I use a Critter sprayer which is a siphon feed sprayer, so you will have no problem with a conventional siphon feed gun.
The HVLP gun should work fine, can you adjust it for air pressure and fluid flow? Is it gravity fed?
Old 07-09-2010, 02:36 PM
All you can adjust is the fluid flow. Here's a link to what I have. I should have taken a picture to show you.
http://www.tptools.com/p/2992,60_Sho...aint-Guns.html
Old 07-09-2010, 03:12 PM
Wiki Edits: 22
I think the problem is in the warmed air from the turbine, and I think it will be a problem no matter what kind of gun is attached to the turbine, but if I were you, I'd call these people, tell them what you're spraying, and ask them what to do to get the glue to spray better. Try the primer gun, it should have a bigger nozzle than the HVLP gun. Maybe that will help.
Old 07-09-2010, 05:57 PM
I'm thinking the warm air as well.
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 02:18 PM
one giant orange peel flamedfordbronco Body - Exterior 14 06-20-2007 09:04 PM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
