K10 ignition switch moves with column shift - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2011, 07:01 AM
carlk4728's Avatar
When I shift through the gears on my 87 Chevy pickup, the ignition switch and its housing move along with the lever for about an inch or two. In other words, when I shift from park to drive, the ignition switch (along with its housing) rotates about 45 degrees clockwise (inconsistently). I'm hesitant to pull the steering wheel off without having a good idea of what's behind there.
Does anyone know how that ignition switch assembly is fastened to the column, and how it may be damaged in my case? This truck does have tilt.
Thanks
Old 04-03-2011, 06:34 PM
You might find this helpful
http://www.yesterdaystruck.com/trfor...ges/26956.html
steering column/ignition switch redsag 78 Suspension - Brakes - Steering 2 01-09-2009 05:02 PM
GM Column ignition Switch Randy BB Hotrodding Basics 3 06-17-2007 08:08 PM
gm tilt column ignition switch mikoman Electrical 2 10-24-2006 06:38 PM
How do I remove the ignition switch from a GM steering column, 1972? jpd37 Electrical 5 04-17-2006 04:30 PM
steering column shaft moves RodFather Suspension - Brakes - Steering 11 01-13-2005 04:13 PM
