K1500 ABS disabling? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2011, 03:25 PM
Wiki Edits: 31
My '95 K1500 has developed a bad brake 'grab' at times, when it's first started to be driven ( clears up after a few miles ). Many times this is accompanied by an ABS light.. Asked the mechanic I use about checking the ABS codes with his scanner and he said to just pull the fuse and drive it, as the OBS trucks are better without it, which is not the first time I'v been told the primitive Kelsey Hayes system is no good, and it no longer activates anyway. it used to, but never like it should.. I do not like lights on the dash and will not perform this 'modification' unless the dash light can be turned off short of cutting wires or pulling the bulb, or black tape.. Problem is, I'm not even sure the grab is caused by the ABS .
can ABS light be turned off?
Old 11-16-2011, 08:00 AM
There are millions of these trucks on the road with the factory ABS working just fine (mine being one of them). Find a mechanic who has a clue, or buy a factory service manual and learn how to fix it yourself.
tbi 350 k1500 cam help? musclecarsrock68 Engine 34 07-27-2011 09:16 PM
95 tbi k1500 hp musclecarsrock68 Hotrodding Basics 34 07-19-2011 04:17 PM
91 k1500 350 tbi gabes91 Engine 3 02-21-2011 10:48 AM
92 chev k1500 4x4 budnick Suspension - Brakes - Steering 1 04-04-2008 01:38 PM
disabling rear drum brakes nitro3421 Suspension - Brakes - Steering 3 03-14-2006 05:47 PM
