K1500 NV-3500 to NV-4500 swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2011, 12:50 AM
Wiki Edits: 31
My 1995 K1500 has always had some transmission noises and shifting issues since I'v had it, which is common for the NV-3500's. lately it has been jamming out of 3rd both on up shift and down shift, tho I can eventually get it into 3rd. I always browse for a 4500 to swap in knowing eventually it's going to need a trans. Searching car-part.com in a diffrent way than I usually do, found a back woods yard that not only is connected to the service ( which I didn't know ), they have 1 from a '94 K3500. I'v heard the owner is a bit 'off' so I'v never given them much thought, but providing the truck is fairly complete, all the swap peices are likely there.. It is from a diesel truck, but I know that only means there is a dampener on the output shaft.. What all do I need to make it work? I know the crossmembers are diffrent, but coming from a diesel, is there anything that won't be there or wrong for what I need, like a diffrent flywheel, or could the NV-3500 flywheel be resurfaced and work?
Old 08-01-2011, 01:27 PM
Wiki Edits: 31
Found an SM-465 in a '90 K3500. any thoughts on that?
1993 GMC Vandura 3500 HD transmission swap sthrninhp Transmission - Rearend 2 06-11-2011 08:55 PM
Manual to Power doors swap 1990 k1500 4x4 Chevy350Sb Electrical 1 04-06-2010 09:40 PM
building a 500+ hp sbc for under $4500 Tryin2MakeIt Engine 28 07-23-2009 02:14 PM
1993 Silverado K1500 auto to manual trans swap.. FinishLine Transmission - Rearend 1 01-11-2009 08:42 PM
transmission swap.. 1995 chevy 3500 2wd 454chevy Transmission - Rearend 1 02-27-2008 05:58 PM
