Keep Getting Header Leaks-any Ideas? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2011, 01:46 PM
chevyrestore's Avatar
Hey guys, ive got a 1980 454 engine, seems like I keep getting header leaks. I put on new mr gasket performance header gaskets (the ones they sell in the performance aisle in auto parts stores) and it seems like every 6 months to a year they leak again. Any ideas on what type of gasket or brand I should use and what to do to keep it from leaking?
Old 12-22-2011, 02:31 PM
DoubleVision's Avatar
Stock paper replacement header gaskets are supposed to be soaked in water
so they expand and hold moisture. However, I stopped using paper header gaskets way back in the early 90`s. I use stock exhaust manifold gaskets which are meshed steel. Not only are these tough and really resist burn out, but they`re also slotted so they drop in instead of having to remove all the header bolts.
Old 12-22-2011, 02:40 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You could also check/tighten the bolts periodically, also check the flange for flatness.
Semper Fi
Old 12-22-2011, 03:48 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
good heavy gaskets with metal in them
then cover both sides with a thin layer of permatex ultra copper RTV
and check to make sure the bolts are tight once in a while
Old 12-22-2011, 03:52 PM
cool rockin daddy's Avatar
Proper gaskets and preparation along with safety wiring the header bolts or using Stage 8 locking plates.
Old 12-22-2011, 04:34 PM
poncho62's Avatar
Wiki Edits: 5
I use the stock steel gaskets too. Once installed retighten the bolts every few heat cycles for a few days......never have a problem when doing this.
Old 12-22-2011, 05:08 PM
kleen56's Avatar
You may want to check the surface of the header that bolt up to the heads to see if it's warped or bent. If that's the case, they gonna leak. It's a pain to check because you have to remove the header and place it on a perfectly flat surface. I used vaseline on the surface and then put the header on the flat surface and see where there is no vaseline marks, that will be the area that is not flat and probably leaking. Otherwise, I'm with the rest these guy, good metal gaskets and I use the Copper RTV like matts37 mentioned.
Old 12-22-2011, 07:29 PM
Zeeb's Avatar
One thing not mentioned was "dead soft aluminum". I kept cracking and getting leaks in conventional gaskets on my SBC. Went to dead soft alum - problem solved. Did have to retighten after a couple of heat cycles.
Old 12-22-2011, 07:59 PM
Wiki Edits: 27
slots ?
sometimes you can saw some slots in the header mounting flanges. the heating of the headers can cause them to want to warp as they heat and cool unevenly I ve seen guys heat the pipes 2 or 3 inches from the flange after they are torqued to the head to stress releive them.
Old 12-22-2011, 11:31 PM
DENCOUCH's Avatar
I have used the soft graphite gaskets with success (expensive tho...). I used to double-up on header gaskets & install two instead of one. Sealed pretty well that way. Just my two cents on this.
Old 12-23-2011, 11:35 AM
hedder leak
mr gasket r summit copper header gaskets with lok washers on header bolts ! it works running six hundred hp on the street!!!
Old 12-23-2011, 11:36 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Jumping on the stock manifold gasket wagon. With the others when a bolt loosens your done. With the stockers you can retighten and go some more or drop a single in if needed.
Old 12-23-2011, 08:04 PM
1971BB427's Avatar
I think it was probably 35 years ago or more when Car Craft wrote a tech article on how to make inexpensive headers seal well. I had just purchased a set of $59 headers for my big block Camaro, so read the article with much interest.
The main theme was that most inexpensive headers had flanges that weren't perfectly flat, and didn't seal well. They showed how to merely cut between each tube to spearate the flanges and allow them to individually seal to each exhaust port. I took mine new from the box and used my portaband to remove most the metal between each tube, leaving just 1/2" around each bolt hole.
When I was done I bolted them to my big block, and 25 yrs. later they were taken off when I rebuilt the engine, and still no leaks. Put them back on it after the rebuild in early 2000, and still no leaks today! Same headers for 35 years, and the cheap fi really works for me!
And all this was with the inexpensive paper gaskets made by Mr Gasket.
Old 12-23-2011, 11:10 PM
bentwings's Avatar
bentwings
Pretty good. i use soft solid copper gaskets. When I take them off I heat them nearly red and drop them in cold water. This anneals them back to dead soft. It helps to add a very fine copper wire intothe groove too. I usually just silicon seal it enough to keep it there untill I tighten the blots. this then imbeds into the copper. seals very well. It doesn't hurt to tighten the bolts occasionally.
Old 12-23-2011, 11:15 PM
1971BB427's Avatar
I use those copper gaskets on my fenderwell headers for my Austin gasser at the collector caps. Since I often uncap to run open, I got tired of replacing the cheap gaskets that stuck and wore out.
Mine don't seal perfect, so I think I'll try your way and anneal them so they're softer. Might help the little leaks at the collector block off plate.
Ceramic header mods ideas needed Nonhog Engine 3 07-07-2010 09:24 AM
oil leaks DeaconJ Engine 2 05-27-2010 01:22 PM
Oil Pan leaks my oldcar Hotrodding Basics 4 11-15-2009 07:43 AM
gas cap leaks cares General Rodding Tech 2 07-16-2006 07:27 AM
Header wrap on one section of header Sparky06 Engine 4 07-27-2005 10:01 PM
