Keep going through spark plugs, need some advice. - Page 8 - Hot Rod Forum : Hotrodders Bulletin Board
  #106 (permalink)
Old 04-19-2010, 10:14 AM
Bill Adkins's Avatar
Still learning .... happily
Actually I have owned a couple of Sun 1115's, the earlier models that were real time patterns rather than electronic sample rate machines, that accompanied with a wide band setup is all thats needed. As far as the dyno goes I worked on two different ones, both in ground Claytons also from a time gone by The later had flywheels to simulate road load and the first was just a load and go machine. Neither were all wheel drive as most of todays but most muscle cars don't have front wheel drive. I'm sure they were both donated to some school and replaced with a detail station LOL
  #107 (permalink)
Old 04-19-2010, 10:50 AM
eric,
one step one test at a time...
hook up the ground batt to the shell first and drive it...
leave the module alone for now...
re: second/third set of eyes...
it is just too easy for anyone to not see something immediately obvious to someone else causing a fault or could be made better is why I recommended it...
ex:
you described the harness plug in connect as "flimsy",,,can be a simple as just improve/better secure that to cure the miss...
that kind of judgement call we can't make over the net and so so darn often it is a simple to fix problem source!!!
(that doesn't need 20 tests to sort out the source)
  #108 (permalink)
Old 04-19-2010, 02:23 PM
Ok Red I will do what you said. I am not driving my truck the next couple of days but will be getting it out Wednesday evening cause I have to drop it off cause I am getting a new set of rear end gears put it. My other ones has seen better days. I will pick up some 12 gauge wire and hook it up.
Thanks Eric
need help finding the right spark plugs Icelander Engine 1 02-19-2009 08:27 PM
Spark Plugs esahlin Electrical 1 09-09-2008 06:45 PM
Edelbrock heads / spark plugs ? driveability Engine 8 03-13-2006 07:29 PM
Dart iron eagle spark plugs... killerformula Hotrodders' Lounge 10 09-18-2004 11:33 AM
Question Performance spark plugs for 98 mustang gt sungho General Rodding Tech 11 08-14-2003 01:00 PM
