Keep overheating
Ok folks, here's the situation, i have:
355 SBC making 450hp. 16" electric fan 11:1 Compression with AFR 195cc heads (aluminum) 2x1" core aluminum radiator 160* thermo Tranny cooler 41* overall timing (yes, that is right 41) Stock waterpump (yes it works) And in traffic the damn thing still overheats!! like 210* in stoplight traffic... but will cool down to 190* when going 55mph+ No shroud, no flex fan. Any other suggestions? I am going to try and put a new 180* thermo to see if that helps. |
Aye, that was my idea as well.
Just trying to get second opinions
I would switch to either 190 or 195F thermostat.
Mine runs at the same temps because my temp sensor is installed in the LH head. You will get higher readings from there. Where is yours installed? And, of course, like someone suggested a good shroud setup. Are you using a 50/50 mix? Regards, Denis '67 Camaro RS |
210 is fine not ideal but fine.......anything over 220 then you have to start worrying........................shroud is a big problem.........dont run a 50/50 mix run 70% water and 30% radiator fluid.......Add a bottle of water wetter and ill bet you will drop about 5-7 degress in traffic.......good luck
I agree and think 210 isn't that bad. I wouldn't worry until it started getting higher than 220 or so. A shroud will help tons as will a high flow water pump (stewart makes great ones). I usually put in a 180 thermostat, but I don't that that will have any effect on the heat situation.
Question, as I have a similar situation. My fan is attached directly to the radiator, how is a shroud utilized in this configuration, does it space the fan off the rad so the fan draw's or blows trough the whole surface??
Thanks |
i second everybody else's notion with a FAN SHROUD....that will help greatly.
210's nothin especially if the temp probe is in the head, if it is, install it in the intake coolant crossover. Temps don't vary so wildly in that location.
Outlawed tunes from outlawed pipes |
How do you guys feel about two electric fans? I currently am running only one electric fan on my 4 core aluminum radiator in my 66 mustang (mustang radiators are ridiculously small) and i'm wondering if i should put a pusher electric on it or should i move my puller electric to a pusher and install a mechanical fan? I'm over heating when i sit in stop and go traffic however the moment i start moving the temp drops dramatically.
Centerline |
