Here would be my suggestion:
Squeeg’s is now offering a clear epoxy with the same characteristics as our colored suede epoxy. Our clear epoxy is designed be used over all types of metal, including bare sheet metal on cars, manifolds, wheels, brackets, fasteners, and just about anything you would like a clear finish on.
It will NOT peel and flake like urethane and enamel based clear coats.
It may also be used over the top of our colored suede (Satin Finish) epoxy. Special effects can be created using dry pearls. The possibilities are endless!
It is available in a suede or gloss finish. If you have a beautiful bare metal finish and want to show it off, coat it with our clear epoxy and drive it all you want, rain or shine, and never worry about moisture affecting the finish of your metal work!
***************************************888
Reason: Commercial ads not allowed in forums..
