Keeping body filler out of panel gaps? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2011, 11:52 AM
boris_thespider's Avatar
I'm installing the trunk, hood and doors on my fiberglass kit car. The gaps between the panels are pretty close, but I need to use filler to level the panels to each other. I would like to spread the filler right across the gap and sand both panels flat at the same time. Is there something I can put in the gap to keep the filler out? Something that comes out easily once the filler is dry leaving a nice, clean edge on the panel? Thanks...
Mike
Old 07-22-2011, 12:10 PM
The oldest trick in the book, stick a piece of cardboard in the gap. Fill it right up to the cardboard and after the filler sets simply break the cardboard off and sand it flat, gap is perfect.
Old 07-22-2011, 12:11 PM
Here is a basics on the subject.
http://www.autobodystore.com/ms12.shtml
Old 07-22-2011, 08:46 PM
Thank you for the tip, Brian
Optimum Panel Gaps? ant_8u Body - Exterior 20 08-15-2011 08:04 PM
327 in 55 chevy panel. Worth keeping? imagefxphoto Engine 9 05-29-2010 09:22 PM
door edges and panel gaps robs ss Body - Exterior 4 07-11-2007 07:45 PM
body gaps over tightening robs ss Body - Exterior 7 09-30-2006 02:58 PM
Panel Gaps Drides Body - Exterior 6 03-24-2006 08:16 PM
