keepitcleanwiring aftermarket harness - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2009, 01:27 PM
i am having trouble figuring out how the flasher circuit works in the keepitclean aftermarket panel/harness that i installed in my shoebox ford.i am trying to get my turn signals working .i have an aftermarket column switch and its instructions show diagrams for both a 3 prong flasher and a two prong.In my panel i have two 2 prong flashers.why?which one do i use?also--do flashers fry easy?i had a bare bulb flashing at one point grounding it to a screw but not anymore.thank you
Old 05-29-2009, 02:40 PM
46highboypu's Avatar
Last journal entry: More pin stripes
carbrainiac, I answered your PM but should have added a note. I saw in Rod and Custom a month or so ago in the article about putting a steering column in Keven's '48, that he had the same signal unit we do and what looked in the photo to be two flashers under the dash. So I quickly went to R&C's web site and asked him about it...turns out he couldn't figure it out either. This month they say to ask the supplier of the unit or the harness. Some help?!? I wish I could have been able to get in the cab with the guy that fixed mine so that I could tell what he did.
Good luck and let me know how it turns out.
Drive an aftermarket elect speedo with stock 4L60E harness and sender? flynbrian48 Electrical 3 02-18-2009 06:54 AM
headlights aftermarket harness 78 monte Electrical 9 07-02-2006 06:51 PM
Wiring Kits crazygutgut Electrical 40 12-15-2005 07:49 AM
aftermarket harness = confused Blob Electrical 7 10-18-2005 07:51 AM
changing engine wiring harness, ran into a lil problem ikeaguirre14 Electrical 9 06-02-2005 05:01 PM
