keg gas tank - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2007, 10:06 AM
keg gas tank
need to know how to make keg gas tank the right way. legs filler neck legs sending unit. IT is going on S10 bed is it safe place.
Old 12-23-2007, 07:39 PM
are you wanting an actual keg tank or a traditional aluminum fuel tank?
Shane
Old 12-23-2007, 08:12 PM
Last journal entry: frame build
Tig a filler neck on the bung on the side. Cut the dip tube out of the end and weld a plate on . this plate can be a place to mount a screw in mechanical fuel gauge in addition to your fuel pickup. The pickup can also be placed in the bottom of the tank or in the end wherever you prefer. Mounts can be made out of 1/4 plate cut to a shape that you like as long as it provides support to at least a quarter of the diameter of the tank. T weld a 1" wide strap where the tank sets and put a fabric strip on it to cushion the tank. Hold downs can be of the same 1" strap, dog collars, leather belts or sequined spandex. Whatever you like as long as it is reasonably fuel resistant. A ground strap should be ran from the tank to the frame. Tanks are available in several sizes but the 15 1/2 gallon is the one usually used . Old barrel type kegs are availble from collectors and not very expensive.
Need new gas tank thecaptive Hotrodding Basics 6 05-22-2006 06:02 PM
32 'Tanks' gas tank - fuel surge/starvation? Limey Simon Engine 2 07-30-2004 02:18 PM
gas tank pressuring up montea General Rodding Tech 3 06-04-2004 09:37 PM
diesel in gas tank help asap mike69scj Engine 15 05-30-2004 10:52 PM
original 1936 ford gas tank fitting bomo General Rodding Tech 5 12-04-2003 05:20 PM
