keith black pistons - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2012, 10:32 PM
New Member
keith black pistons
Hello folks, hope everyone had a Merry Christmas. Want to ask if anyone has expereanced any problem with Keith black pistons, when used in a 351 cleveland 1972, 0.030 over bore .I've been told that there could be a breakage problems, the engine is a mild build compression 9.5 to 1 all new internals except crank, new intake elderbroke performer. and new 650 carb.
Old 12-29-2012, 01:18 AM
F-BIRD'88's Avatar
Yada Yada Yada
Read and follow the specific instructions for piston ring end gap for these popular pistons and you will
not have problems with these pistons.
Old 12-29-2012, 07:58 AM
1Gary's Avatar
Last journal entry: Ole Yellar build-1989 383 SBC Astro build
This is a chart for a SBC I-Con pistons and what you should be looking for in the box.
Old 12-29-2012, 10:44 AM
BOBCRMAN@aol.com's Avatar
The people that have breakage problems with KB pistons are the people that don't read instructions or understand the design/construction of these pistons.
As mentioned, ring gap is a major consideration as is piston to wall clearance.
Old 12-29-2012, 10:48 AM
Pistons:
Stock and 4032 alloy cast hypereutectic, 11% silicon...........up to 450 HP
Aftermarket 2618 alloy forged, 2% silicon ........................up to 1200 HP
The choice is yours.
Old 12-29-2012, 10:43 PM
used the hypers and the icons never ever a problem . and have run 15lbs boost with alky on the hypers in the smallblk. end gap per instructions
Old 12-30-2012, 12:13 AM
1Gary's Avatar
The feature I like on the I-Cons is the design of offset pins to limit cold piston slap.For the street,press fit pins are the way to go.
connecting rods, ford engine, kieth black pistons, rebuild
installing Keith Black pistons Icelander Engine 4 03-30-2009 04:04 PM
Keith Black Pistons PASNAKE Engine 18 11-17-2005 11:56 PM
Keith Black 121 pistons chevyelc81 Engine 3 01-27-2005 08:32 PM
Keith Black Pistons Problem tornado-tech Engine 17 11-16-2004 10:04 AM
keith black.. hyperutechtic pistons monte3406 Engine 18 12-08-2002 08:08 PM
