Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Keith Black Pistons Problem
Old 11-07-2004, 01:12 PM
tornado-tech's Avatar
tornado-tech tornado-tech is offline
Ok. If I went with the Wiseco flat-tops and a .044 head gasket which should give me better quench, would I need to rebalance the entire assembly again if the former balance job had everything weight matched for the heavier Keith Blacks. This is an internal balance motor. I just bought a set of the old Summit Sportsman II's (68cc, 2.05/1.6) for little money from racing friend that look identical on the outside to my s/r's. I know I will raise compression but plan on running Sunoco 110 to avoid future problems.
