key hole cover - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2011, 05:21 PM
key hole cover
Hello, i need to build a custom key hole over for a trunk i am building. i want to use my own logo, not a car company's. my question is how does that swivel on a key cover work? i am not sure what i need to make the cover swivel back.
any help appreciated. thanks!
Old 07-09-2011, 01:52 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
on a diy cover attach a stud where you want the swivel to be and then put a self locking nut on it so you can adjust the amount of slack so it will swivel easy..the stud goes at the top of the logo so gravity will help hold it in position when it is closed..
Sam
Old 07-27-2011, 06:15 AM
thanks for responding. i am going to try that. however, my keyhole wont be on the side of the trunk or vertical, it will be on top of the trunk, horizontal.
Sam
Old 07-27-2011, 10:04 AM
evolvo's Avatar
Heathen
Once you get the swing action figured out you'll need a way to hold it shut, since gravity won't be much help. I think you'll need to figure out how to mount a detent to hold it firm. Check these guys out
http://www.springandballplungers.com/
Good luck
Old 07-27-2011, 10:05 AM
To add to the self locking nut, I'm picturing a spring. The nut tightens against the spring to allow it to move a bit when pivoted plus stay in place afterwards.
Old 07-29-2011, 08:33 PM
thanks for the tips and link,guys! it looks like i will have to test it out when the time comes. (i still have to design and cast the parts.) i will how it turns out or if i have problems.
Good luck
KMatch
KMatch's Classified Ads
2 hole exhaust flange connecting to a 3 hole JLBpontiac350 Engine 0 04-26-2011 02:31 AM
Cracked steam hole going to bolt hole projectman69 Engine 4 11-10-2010 07:54 AM
Drilling oil fill hole in Aluminum Valve Cover ssmonty Engine 10 07-30-2007 09:04 AM
Pictures: Hole In Radiator Hose/Burned Spark Plug Boot/Melted Dust Cover And More!!! Ghetto Jet Hotrodders' Lounge 2 12-06-2004 10:13 PM
where to get a plate to cover the air con.hole. yellowtail Body - Exterior 2 08-11-2004 02:59 AM
