Key Off Fuel Pump Running - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2005, 05:39 PM
greg67's Avatar
New Member
Hello..i Have 94 Gmc 3500 And With The Key Off The Fuel Pump Is Still Running . The Weird Thing Is That For Some Reason The Pressure Switch Is Not Shutting It Off.
Old 05-16-2005, 06:32 PM
NorthStar's Avatar
I think you have a pump relay that is stuck in on position.
The oil pressure switch gets its 12+ wire from the computer so it should not be able to power the pump when key is off even if it stuck in closed position too.
Old 05-16-2005, 07:19 PM
greg67's Avatar
New Member
I HAVE REPLACED THE RELAY AND IT IS STILL RUNNING
Old 05-16-2005, 08:23 PM
NorthStar's Avatar
Try disconnecting the relay see what happens.
Try disconnecting the oil pressure switch see what happens.
Check continuity of oil pressure switch with a test light to see if closes a circuit when truck is started.
Should be an open when theres no oil pressure and close when there is.
Check to see that there is not voltage at all times on pump relay activation wire.
Possible that theres a shorted wire to 12+ somewhere.
Old 05-16-2005, 09:49 PM
greg67's Avatar
New Member
Thank You........... You Were Right . There Was A Short At The Oil Pressure Sender Wires.
Oil leaking near fuel pump..what the heck??? HotRodF100 Engine 13 01-08-2012 06:03 AM
351 W fuel pump connection???? DDGETHS Engine 2 02-15-2005 02:12 PM
electric fuel pump recommendations stea Engine 2 06-27-2004 09:38 PM
Bad fuel pump??? ffcagle34 Engine 2 06-21-2004 12:15 AM
Question for Edelbrock Performer fuel pump owners HotRodF100 Engine 1 07-20-2002 05:47 PM
