key unlocks wheel but wont turn past - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2012, 10:02 AM
91camaroRS3.1
so the key in my 91 camaro will turn juust enough to unlock the wheel but no farther, not o acc. not on not anything. when the steering wheel unlocks the wheel turns and makes a clicking noise. im lost and getting fresterated. idk.it just wont turn, iv tryed juggliing, realy craaankiin the wheel. i cant get any father.
Old 03-10-2012, 10:08 AM
poncho62's Avatar
Wiki Edits: 5
Sounds like the tumbler in your column is messed up......You need to replace it. Not sure if you need to remove the wheel to get it out, but I think so.....Maybe someone else on here knows the procedure.
Old 03-10-2012, 10:19 AM
91camaroRS3.1
yea, i would need to pull the steering wheel but idk how to do that considering its got an airbag. its was deployed by the last owner and im pretty sure it was just stuffed back in there..
Old 03-10-2012, 07:28 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Disconnect the battery and remove any air bag fuses.
Old 03-11-2012, 01:08 PM
91camaroRS3.1
ok well i pulled the whole steering colm apart, rerouted the VATS wires from the tumbler, so now i have a tumbeler under my dash with the vats hooked up, u gitta put the key in the ignition and crank it with plyers. success or failure...idk...lol
SBC 350 Wont Rev Past 4500rpm? SB7 Engine 14 10-29-2011 09:07 PM
350 wont rev past 1600 wakawu Engine 14 10-28-2009 04:56 PM
wont rev past 3000 camino_man Engine 8 07-07-2004 06:21 PM
wont rev past 6k corona jon Engine 33 05-21-2004 02:12 PM
wont rev past 6k corona jon Engine 8 12-28-2003 08:53 PM
