keyless entry - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2005, 08:46 PM
astrops's Avatar
keyless entry
i have a 2003 gmc sierra....and my number one remote needs to be programed, however, gm make you pay an hour labor to do this....does anyone have any idea how to do this.
Old 05-08-2005, 09:12 PM
1tonkatoy's Avatar
New Member
try this
Method 1 - No Tools Required, Program All Transmitters
Important
All transmitters which are to be recognized by the PDM must be programmed in a single programming sequence. When using this program method, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter.
The order in which the transmitters are programmed will determine its numbering position within the PDM memory. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number stamped on the transmitter case is for reference only; #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available.
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to 4 transmitters.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
Operate the transmitter functions in order to verify correct system operation.
biometric rfid keyless entry Jon Hotrodders' Lounge 9 04-02-2005 09:29 PM
GM Keyless Entry Problem jradf Electrical 1 11-20-2004 02:09 PM
keyless entry in a 73 monte carlo? 73monte Electrical 2 11-29-2003 08:26 PM
GM keyless entry val Electrical 1 09-17-2003 06:38 PM
Keyless Entry 4811 Electrical 3 03-28-2002 05:47 PM
