keyless entry problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2009, 07:54 PM
Radchop's Avatar
Last journal entry: ...
I purchased a REC43 keyless entry system for my door poppers. The remote worked great for the first few days. Now they seem to work only when they want to. Has anyone had this problem with there keyless entry?
Old 03-10-2009, 04:45 AM
sounds like maybe a ground wire is loose. or maybe the remote battery is weak? (its only like a watch battery)..
Old 03-10-2009, 09:51 AM
Joe G's Avatar
Yeah, It sounds like it's either a bad remote battery, or YGWYPF (you get what you pay for).
I looked it up on the manufacturers website trying to find an installation manual, and they must have discontinued it... maybe for a reason. Might be why you can buy them ten different places on Ebay.
Their current models have some kind of protection mode to prevent or detect the addition of unauthorized remotes - as in, if a crook wants to steal your car, he can program a remote to your system by standing near your car while you have the key in the run position, or something like that. So maybe the receiver is in some kind of protection mode.
If you've tried both remotes and neither one works any better than the other, one more thing I'd try (if you haven't already) is to reboot the receiver by disconnecting the car's battery for about 30 seconds and hooking it back up.
I'm not ripping you for buying an inexpensive controller. I'm all for getting a good deal. But, I've had trouble with these in the past. Not sure if it is the case here, but sometimes unscrupulous manufacturers will intentionally dump a load of defective products on the wholesale liquidation market. Ever seen the late night TV infomercials that say "You can buy name brand products for pennies on the dollar and sell them online for big $$", that may be what's going on here.
Or maybe you just got a bad one.
[/mini-rant]
Hope this helps
Joe G.
Old 03-10-2009, 07:01 PM
Radchop's Avatar
YGWYPF is what im thinking as well. What kind of replacement would you guys recomend? And where can a buy it? Also I have the unit grounded to my engine block, that should be good enough right?
Old 03-10-2009, 09:25 PM
Joe G's Avatar
Yes, assuming that your engine is well grounded to the battery, frame and body.
I am partial to Dakota Digital remote control systems. The CMD-4000 system would be well suited to your needs. It's a bit spendy at $125, but the kit includes everything you will need, and the quality is excellent. I've installed at least twenty of these systems in the last five years, and haven't had a failure yet.
I buy them from my local hot rod parts store (Ed's Twin City Rod & Custom in St. Paul). In your area, the Dakota Digital dealer is Mild to Wild Classics.
http://www.mildtowildclassics.com/
DEI is another brand I have had good luck with. They're the same company that makes Viper alarm systems. They offer a keyless entry system for about $60, but depending what kind of latch actuators you have, you may also need to buy a couple of relays. (if you have the actuators that go "zzzzzit" you're OK, but if they are the ones that go "THUNK", you will need extra relays).
(click for link)
These might be available at your local Best Buy store too, but I'm not sure.
Good Luck
Joe G.
Old 03-10-2009, 09:31 PM
Joe G's Avatar
Hey, I just checked out your project journal.
That is a great looking Galaxy!!!
Old 03-10-2009, 10:13 PM
Radchop's Avatar
Thanks Joe G! I'll check out Mild to Wild in the AM.
overcharging problem on 1972 mustang DaSouthWon Electrical 6 08-27-2008 08:17 PM
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 11 07-19-2007 08:07 PM
I'm having a primer adhesion problem on one door Ripped Body - Exterior 10 06-08-2007 12:45 PM
96 Plymouth Voyager spark problem? baddbob Electrical 12 05-19-2007 03:44 PM
Puzzling temperature problem on the hemi solved Centerline Engine 2 11-26-2004 03:48 PM
