Keyless entry system - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2006, 10:40 AM
Hi
I've been thinking about putting a keyless entry system in my 87 caprice with power locks. There are a lot of these systems out there now and I was wondering if anyone has had any experience with any of the fairly cheap models. A lot of them now go for under 50 bucks, especialy on ebay. Are these worth buying? Also are these systems pretty staight forward as far as installation goes.
Thanks
Old 11-09-2006, 04:42 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
I'd Be Leary of anything on Evil~Bay..your likely to get a box full of air.
You only need the RF unit and Control interface, You should be able to find a fairly Cheap unit at a good auto Stereo / Alarm Shop, And it's local, if you have any problems putting it in..
Swap meets are another source.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 11-09-2006, 05:33 PM
How easy is the installation?
Old 11-09-2006, 05:47 PM
If you already have power locks, a keyless entry system is a very easy installation. There is a small reciever box that you mount under the dash, and you have to find a point to connect into the power door lock switch.
I'd say $60 is the upper limit for what you should have to pay for this type of setup from a third party company. I once priced the Ford dealer-installed upgrade for an '89 Taurus I used to have, and the OEM upgrade was only about $100 from Ford.
Bruce
Old 11-09-2006, 06:19 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
What He said!
You should need only interface the RF box and output control wires to an area in your harness where you can parallel the lock wires from your Module, (+up -DN .. LF, RF, RR, LR) into your main harness for the switches to the door locks..usually in the center console or the Left door or side (kick) panel.
Doc
Innovations
Charging system info............... poncho62 Electrical 11 11-26-2005 09:53 PM
biometric rfid keyless entry Jon Hotrodders' Lounge 9 04-02-2005 10:29 PM
GM keyless entry val Electrical 1 09-17-2003 07:38 PM
anyone familliar with keyless entry systems? HotRodF100 Electrical 3 05-11-2002 02:27 PM
Keyless Entry 4811 Electrical 3 03-28-2002 06:47 PM
