Kia doesnt always start - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2007, 08:56 PM
My friend has a 1999 Kia Sportage 2.0 / 5 speed that doesnt always start. Sometimes he turns the key and it takes right off and other times turn the key and nothing the starter doesnt engage or turn ...like its not even getting power and sometimes if you hold the key in the start position the starter finally works and it fires right up. His oil cooler or oil filter started leaking oil and got some on the starter.The oil leak has been fixed , Could this have caused the problem? Would spraying the starter with electrial parts cleaner help,It wouldnt cause it to go on out would it?
Thanks
Shane
Old 12-13-2007, 09:49 PM
68firebird
The problem is that it's made/engineered in Korea but we will over look that. Sounds like a wiring issue....I would start by checking the wires and connections by the starter.....Do you have a multimeter????
Old 12-14-2007, 07:07 AM
poncho62's Avatar
Wiki Edits: 5
The oil may have done something to the starter....check the connections first...If that doesn't solve it, I would take the starter apart and make sure all is well in there.
Old 12-14-2007, 07:40 AM
Frisco's Avatar
Glad To Be Here
Check the battery cables at the battery. Corrosion at the terminals will cause this condition. Clean the battery posts and the inside of the battery cables. The corrosion will look like carbon deposits.
Old 12-14-2007, 04:44 PM
Yes I have a multimiter... the cables looked pretty good, the battery posts were a little corroded and cleaned them off.Didn't really have the chance to go any deeper into it than that at the time.
Shane
Old 12-14-2007, 05:05 PM
Wiki Edits: 31
check the floormat position under the clutch.. Kia clutch cut out switches require the clutch fully depressed. just a thought.. my brother went thru that with his '01 Sephia
Old 12-14-2007, 09:05 PM
I'll tell him to check that too.
Shane
Old 12-29-2007, 10:33 PM
Checked It out today and it wouldnt not start but had failed to start like 12 miles down the road .
Shane
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
crank no start meev182 Engine 7 06-17-2007 06:27 PM
chevy 350 won't start Troy Smedley Engine 2 03-23-2007 05:21 AM
My truck wont start. 91 serria 350 tbi montea Engine 17 12-17-2006 04:23 PM
caprice wont start? Brian Morency Engine 8 08-24-2004 11:37 PM
