kick back - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2006, 12:58 PM
kick back
have a 350 sbc with performer rpm heads, cam, intake. Runs well and starts fine but every once in awhile when shutting down it kicks back or desils. the timing is at 14 degrees without vacuume. and total is between 34 36 degrees. what could be causing this and what should the timing be with vacume hooked up? Have accel distributer and coil
Old 05-04-2006, 01:32 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Throttle plates are probably too far open. If you lower the plates then you have a slow idle speed. Are the mixture screws responding favorably?
Try running 16-18 intial timing w/o vacuum and then lower the idle back down to where it is now.
Old 05-04-2006, 01:48 PM
the mixture screws seem to respond normally i did have it at 16 18 but it seemed be worse where would you recommend the idle speed? right now it idles at 750 to 800
Old 05-04-2006, 02:16 PM
DoubleVision's Avatar
It`s likely due to carbon build up, which causes hot spots that get hot enough to make it kick or diesel. Seafoam usually solves the problem. I would set the timing at 12 degree`s before top dead center, and add a adjustable vacuum advance, you`ll have to play with the adjustment to see what it likes while keeping it out of detonation. what we usually do is go up on the timing until it detonates, then back off 2 to 4 degree`s.
Old 05-04-2006, 02:29 PM
As low as it will idle well. 750 to 800 is probably good.
I would look to the idle circuits.
Old 05-05-2006, 07:29 AM
engineczar's Avatar
I merged the two threads by tg40 to keep it all in order.
Old 05-05-2006, 08:06 AM
thanks for merging them didn't mean to make two posts. it isn't carbon build up the motor is freshly rebuilt im going to check the throttle plates.
Dye Back , Dye Back!! 67goat Body - Exterior 3 03-01-2006 03:06 PM
Door Alignment Ron M Body - Exterior 2 08-21-2004 01:43 AM
Back from the stoneage... drgnwgn289 Hotrodders' Lounge 10 10-15-2003 10:41 PM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
