kick down blues - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2002, 06:51 PM
New Member
Post kick down blues
i have a v-8 in my s-15 with a turbo 350. i installed my kick down cable and their is no visible kinks, but it doesn't want to move. when i pull on it or stomp down on the gas nothin happens. can it be my trans or a bad cable.
Old 07-22-2002, 09:28 PM
Post
First thing I would check is to make sure its hooked to the wire in trans then check to make sure its adjusted properly,cable should be at end of throw with throttle wide open.IF adjusted properly and connected correctly vacume modulator etc..and still dosent work I would have it looked into. hope its helpful having trans problems too. V8zguy and GM friends!!
