Kick down cable? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2005, 09:23 AM
StevenC's Avatar
Kick down cable?
On my pickup i changed the intake and carb, I have nowhere to mount the kick down cable on the manifold like the old stocker had is there a special kit for this? Its a vortec performer rpm. Also what does the kickdown do? What happens if i dont use it?
Old 10-15-2005, 11:05 AM
MI2600's Avatar
Member# 3287
You can buy an adjustable bracket for the trhottle cable and kickdown that bolts to the left rear carb stud. You can find them at parts stores. They're cheaper on Ebay, if you're a wily shopper and can wait. I just bought one off Ebay for about $13.00, shipped.
Old 10-15-2005, 08:12 PM
Turbo 350, right? I ran one with the cable disconnected for a while, and had no problems to speak of. Naturally, it would not kick down if I floored it, but you can do that manually if you need to. Mine made the full-throttle-in-drive 2-3 shift noticeable earlier than it did before, but you can manually override that, too. Otherwise, it drove normally, and my trans guy said it wouldn't hurt anything.
Old 10-15-2005, 08:15 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
I don't run one on my Nova. Just manual shift. But MI2600 is correct you can get one at Auto Zone for under 20.00
Kick down cable magic781 Engine 6 06-09-2004 08:56 PM
TH350 Kick down cable Not A T 25 Transmission - Rearend 10 05-07-2004 10:22 AM
kick down cable gumby Engine 2 06-12-2003 12:22 AM
T350 kick down cable Gassman Transmission - Rearend 9 03-14-2003 08:39 PM
How to eliminate kick down cable on th350? brian400ex Transmission - Rearend 1 02-19-2003 02:48 PM
