Kick down switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2008, 06:45 AM
Kick down switch
I have an 89 GMC one ton truck with the turbo 400 3 speed witout overdrive. I was wondering does it have a kick down switch? I think it has a shift kit installed but it still doesnt down shift with a force. Please help.
Old 11-25-2008, 07:36 AM
Yes, all TH400s use an electric kickdown. The switch should be located above the accelerator pedal under the dash.
Old 11-25-2008, 10:40 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Some TBI trucks had the kickdown switch on the TB.
Old 11-25-2008, 11:12 AM
Look under the truck at the transmission on the drivers side. Find where the shifter arm comes out of the case ... move to the rear of the case about 4 to 5 inches or so and you will see a electrical plug with a wire hooked to up. This controls the passing gear in the Turbo 400. ( see photo )
Follow the wire upward and you should find the switch. GM installed them in different places on different vehicles. Some were under the accelerator pedal, others were under the hood on or around the linkage going to the carburetor or TBI
Skylark TH-400 kick down switch msc66 Electrical 6 10-07-2008 08:29 PM
TH-400 Kick down switch Houman SS '70 Transmission - Rearend 1 04-10-2008 05:18 PM
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Starter switch stock to modified wiring question. Kallie49 Electrical 5 06-23-2006 06:01 PM
Edelbrock Carb TH400 Kick down switch lazydawg Engine 2 08-10-2005 02:42 PM
