kickdown cable 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2009, 11:30 PM
I'm putting a 350 chevy with a 700r4 in a Z-car. My question has to do with the proper method for adjusting the kick-down cable at the throttle. We are using a throttle body.
Old 10-25-2009, 11:50 PM
SSedan64's Avatar
http://www.tvmadeez.com/tvinstadj.php
http://purplesagetradingpost.com/sum...o/700R4p1.html
http://www.tciauto.com/Products/Inst...ble_adjust.htm
Old 10-26-2009, 07:33 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The TV cable on the 700r4 trans is important...
You want full pull of the cable at wide open throttle. I hope the TBI you are using has the proper geometry for the cable pull.
Old 10-26-2009, 09:03 AM
302 Z28's Avatar
It is NOT a "kick down" cable, it is a "TV" cable on the 700R4.
Vince
Old 11-01-2009, 09:18 AM
The easiest way would be to get engine and trans from the junkyard directly into your truck, without separating them!
Otherwise, go to the junkyard and get the bracket from a truck similar to yours and use all the stock parts onto yours: the stock system seems to be easy to set up, and no is fabrication needed.
Old 11-01-2009, 03:30 PM
fast68's Avatar
likes chevy trucks & boobies
depress lock button on the cable housing behind the bracket
pull housing back all the way
let go
now open throttle all the way and it should click once or twice
now its set
done
if it doesnt click at all or clicks a whole bunch of times then something may be wrong with the cable or bracket set up or the cable may be stretched junk or the cable may be off the link in the trans
200 4r TV cable - no WOT, hard 1-2, no kickdown 60smotorhead Transmission - Rearend 27 07-28-2009 06:24 AM
700r4 TV Cable Problem jack71 Transmission - Rearend 7 10-25-2006 09:05 PM
