kickdown cable hole - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2012, 11:16 AM
kickdown cable hole
Anyone tell me if using a soft plug when pluggin a kickdown cable hole on 350every turbo if you can poke the rod throuhg the soft plug so i dont have to drop thepan and it still not leak
Old 10-16-2012, 07:16 AM
SSedan64's Avatar
Are you talking about running it like that until you connect a Detent cable later?
I doubt you'll get it to not leak.
Old 10-16-2012, 02:43 PM
kickdown cable
Thanks and yes was gonna do away with kickdown cable alltogether just didnt want to drop the pan again have dropped it several times and never took that out but looks lime i am gonna have to again truck is only driven on weekends and down an eighth mile dragstripon occasion but losin tons of fluid out of the hole where it broke the other day
Old 10-17-2012, 04:33 AM
SSedan64's Avatar
BTO makes these to plug TV cable holes in the 2004R/700R4 Case.
Bowtie Overdrives - View Item
I don't know if it's the same size as a TH350 Detent cable lower housing.
Old 10-22-2012, 01:27 AM
hi i just got an old cable & cut it near the end then filled it with silicone
Old 10-22-2012, 02:17 AM
SSedan64's Avatar
X2^^, that's what most do.
Old 10-22-2012, 11:28 AM
Worth a try thanks!!
Old 10-22-2012, 06:00 PM
39 chev's Avatar
Last journal entry: new pictures of T-bucket
I cut the cable mount right at the flange,and tapped it to 3/8,and screwed a header bolt in flush then put a dab of silicone around it and bolted it back to the trans. Yes I was changing the pan,so I removed the cable internally.
Old 10-22-2012, 10:04 PM
bentwings's Avatar
bentwings
I just got done fixing a broken cut down kickdown plug. Leked TF all over the shop floor. What a mess.
I made a steel replacement tab with a counter bore. filled it with silicone and bolted it on. Problem solved.
Old 10-25-2012, 02:06 AM
i tap all mine and use the sbc oil plugs with the allen heads works perfect everytime
Old 10-27-2012, 12:13 AM
trans cable Plug
I'll second the idea of tapping the hole and using a SBC oil galley plug, really simple and clean install.
cable kickdown malibus~most~wanted Transmission - Rearend 3 04-05-2008 10:12 PM
kickdown cable yragat Transmission - Rearend 17 03-21-2008 03:44 PM
kickdown cable glendale001 Hotrodders Site Suggestions and Help 1 11-07-2006 06:00 PM
kickdown cable underdog305 Engine 1 01-06-2005 08:05 PM
Kickdown cable help! Slant3 Transmission - Rearend 4 05-31-2004 07:05 PM
