Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - kickdown cable on th 350
Old 09-15-2003, 09:21 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
get a replacement cable, unbolt the stub that is left of the old one, you should be able to attach the new cable end to the arm that the old cable end was hooked to, bolt the housing back to the trans case, go topside and attach and adjust for the correct settings, the cable and service book are available from an auto parts or trans shop.
