-   -   kickdown cable on th 350 (http://www.hotrodders.com/forum/kickdown-cable-th-350-a-23538.html)
jum 09-15-2003 09:09 PM
Mine is broken off at the tranny. Any way to fix this? Thanks, Jim
BOBCRMAN@aol.com 09-15-2003 09:21 PM
get a replacement cable, unbolt the stub that is left of the old one, you should be able to attach the new cable end to the arm that the old cable end was hooked to, bolt the housing back to the trans case, go topside and attach and adjust for the correct settings, the cable and service book are available from an auto parts or trans shop.
jum 09-15-2003 09:43 PM
Thank You for answering my ?s
Thank You all, Past, present and future for answering my ?s
