Is kickdown gear same as 2nd on C6 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2005, 07:58 PM
cboy's Avatar
Last journal entry: Finished
When a C6 (or any automatic for that matter) kicks down a gear when you hit the throttle to pass, is it just shifting into 2nd or is there another gear ratio in the trans between 2nd and drive?
Dewey
Always learning...and sharing what I've learned.
Old 08-02-2005, 09:40 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the C-6 has 3 speeds forward.
when you hit passing gear depending on the vehicle speed , it drops to 2nd or 1st gear....... if you were in 3rd gear when the gas pedal was pushed down
Dewey
700R4 2nd gear start/4th gear bind up? myclone1 Transmission - Rearend 3 04-19-2005 02:51 PM
Trasmission Grinding 2nd gear??? StrokeofGenius Transmission - Rearend 1 12-03-2004 09:54 PM
700r4 shifting and 2nd gear . eliotmansfield Transmission - Rearend 4 06-20-2004 03:09 AM
700r4 Skipping 2nd gear ThrottleBottle Transmission - Rearend 4 08-07-2003 03:52 PM
th350 no 2nd gear mkolstad Transmission - Rearend 2 07-10-2003 08:56 AM
