kickdown rod or cable? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2006, 11:03 PM
I have a 72 ford f100 and i restoring it. I had the engine and trans. overhauled and the transmission did not have any kind of kick-down linkage. i have seen use rods for 45 dollars and Locar offers the cables for less. Do I have to search and find the original rod or can I replace it with the newer cable?The engine is a 302 v8 and the tranny is a c4.
Thanks alot
Ray Faubion
Old 11-23-2006, 04:44 AM
I had a 302/C4 in an '80 Datsun 200X about 25 years ago. I didn't have any kick-down linkage either, so I fabricated a cable using speedo cable run through copper tubing. Worked good.
JA
Old 11-23-2006, 08:33 AM
Any aftermarket kickdown kit will work, providing the kit is complete.
The Lokar kits work great, come with plenty of adjustment and good instructions. If you use their kit be sure to order the cable bracket for the carb or you will have nowhere to mount the cable on the engine.
Old 11-23-2006, 01:42 PM
Thanks for the info guys. I was hoping I could use the Lokar cable. Lot easier to find and cost less. Thanks for the infor on full kit and the carb bracket. That was going to be my next question.
Ray Faubion
persistent kickdown cable leak, th350 matt_ramsey Transmission - Rearend 17 09-19-2007 01:31 PM
SBC Destroked Destroked_SBC Engine 46 02-19-2006 12:43 AM
327 in 88 Truck pete379 Engine 101 01-19-2006 09:03 PM
kickdown cable needed? Blob Transmission - Rearend 3 08-17-2005 06:47 AM
powerglide kickdown, rod to cable younguyw/oldcrap Transmission - Rearend 1 11-18-2004 06:58 AM
