Kill Switch
So I know there have been a few kill switch threads here already, but they don't seem to have quite what I need.
So, basics of the car: 1973 Dodge Charger. Pretty much completely stock, 318ci. The coil is mounted pretty much on the backside (read: near firewall) of the intake manifold. There are 3 small wires coming off it: brown, black and yellow, and bluish green. There is also the wire to the distributor. So my question to you: I would like to install a kill switch (toggle would be preferred), how would I go about that? Also, what amps and volts will I need? |
Does having a higher amperage hurt at all?
The term KILL switch is used when discussing a magneto ignition system. A magneto is driven by the engine and generates high voltage internally from rotation. To stop a magneto ignition it needs to shorted to ground to stop the high voltage.
Your system requires an ignition switch. This switches 12 volts to the + terminal of the coil. Any switch rated 15 amps or more can be used. The 1973 mopar, if it has a point type distributor, may use a ballast resister in the ignition circuit that powers the coil in the run mode. A seperate wire from the starter solenoid also runs to the coil 12 volts + to provide full 12 volts during cranking. vicrod |
Also, what wires should I use?
I don't know what you are doing.
If you install a separate ignition switch how will you start the engine? Is the existing ignition switch bad? If so how do you know it's bad? To many unknowns. vicrod |
I would like to install a toggle switch that interrupts the signal from the ignition switch (with the key) to the coil. Theft deterrent. Turn it off, the car won't start.
OK.
You need to find the wire that comes from the fuse block to the ignition switch.This is the main feed to the ignition switch. Cut this wire and connect the "theft switch" terminals to the cut wire ends. vicrod |
Kill switch
I put kill switches in between the battery and the starter, that kills everything, or you can put one between the battery and the ignition, of course you have to use bigger than toggle switches, the wire from the fuse board Ignition switch is a # 14 wire But if you want to tap into it to prevent theft you will have do do it where it can't be found easy or they can just go around it.
later 35terraplane |
The easiest and safest way to install a kill switch on that car is to get a toggle switch, connect one terminal to ground and the other to the negative terminal on the coil. The car will not start while the switch is closed. This is better than trying to interrupt the feed as that can easily be defeated by connecting a jumper wire to the + side of the coil. Also if the switch fails the car wont start.
If you do a clean job my way it is almost undetectable. I did several of these and usually put them under the seat or in the glove box.
Artificial Intelligence is no match for Natural Stupidity Chet |
kill switch
That is if you use a coil, I was thinking HEI. But that will work, the idea is to hide it.
I had a 63 chev. 409 425 H.P. and I had the air cleaner valve, covers everything factory chrome stolen once, so I put a kill switch on it. Had to take it to the shop, forgot to tell them I had a kill switch, which I hit every time I got out of it. The bill to find the kill switch was twice what it was for whatever I took it in for. later 35terraplane |
kill switch
35 terraplane |
| kill switch question... | cutthroatkid | Electrical | 2 | 11-22-2009 01:42 PM |
| Roll Bar Install Advice | Mustangsaly | General Rodding Tech | 12 | 12-02-2007 08:33 AM |
| Wiring a kill switch | hallamwillis | Electrical | 17 | 02-19-2007 05:25 PM |
| Emergency Kill switch question | Mrfixmaster | Electrical | 14 | 12-08-2006 05:52 PM |
| kill switch | shineoneforme | Electrical | 1 | 02-04-2005 06:06 PM |
