Kill switch, coil wire? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2009, 10:51 PM
Hi there everyone,
Just a quick question. 327 Chev in a holden panel van.
When I got it, there was a switch under the dash to which stopped the ignition. I then had various problems with starting, and ended up bypassing the switch, wheich didn't make a difference to my starting problems anyway.
So now I have all that sorted, I would like to wire it back up but stupid me, didn't remeber, or write down what wires it was.
I think it was a simple switch on the wire to the coil, which if switch off stopped the car starting, thats my first guess, or maybe it was the wire from the coil to the points?
Any ideas which one seems more likely? It was running thru a simple switch with no relay, so I assume it was a very low amp wire.
If none of the above make any sense is there another simple way to wire up to kill switch? I would rather not have another pride and joy stolen while I am shopping.....:-(
Thanks in advance for your replys
Cheers
Rob
Old 11-26-2009, 05:34 AM
Assuming you have points and an external coil, the wire simply goes to the distributor side of the coil (should be the "-" side if the coil is wired correctly). With the switch on (closed) the coil is grounded and you'll get no spark. With the switch off (open) the points work normally. I suggest you hide the switch, however.
Old 11-26-2009, 01:12 PM
Excellent thanks for that yes points and external coil.
Appreciate your reply
Cheers
Old 11-26-2009, 01:51 PM
actually, if you are still there I had another look, and it appears I got it all wrong. (although obviously the way above will work tho).
On looking a bit harder, I found the original wire that was interupted. (I had bridged the gap by removing the switch, and running a wire between the spade terminals).
This wire, runs from the alternator to the starter, to I assume the solanoid.
Would this be a better way of doing it than above? I imagine the first way will turn the motor over but won't start, whereas the alternator, switch, solanoid route would stop the thing turning over at all.
If the second way is better, any idea what amps would be running thru from the alternator to the starter? Would a normal switch be ok to handle that current? (I assume its a light current, just to switch the starter relay....)
Many thanks in advance for your help.
Rob
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
Points to HEI conversion; wiring issue?? VI009DZ Electrical 11 06-11-2007 06:56 PM
starter solenoid shorting ignition junkyardjeff Electrical 5 03-24-2007 04:15 PM
Start kill switch 73 nova trenchdog73 Electrical 3 05-06-2005 09:28 PM
