Kill Switch/Wiring. HELP! - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2010, 11:58 PM
I have a 1976 Chevy Blazer and i would like to put a kill switch in it and run it to the coil. There's only one coil and i don't know which color wire i should splice for the kill switch. There is a Red, Black, and a Brown wire, which one should i use for the switch and what gauge should i use to run it all.
Old 07-16-2010, 07:05 PM
pontiacjosh's Avatar
84 stroked ss
Last journal entry: exhaust
i believe it sould be the red wire
Old 07-16-2010, 09:51 PM
Thank you Poniacjosh, and would 10 gauge wire work ok?
Old 07-17-2010, 05:57 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Match the wire gage to the same size as the original 12V supply wire that plugs in at the HEI coil, on top of the distributor. I believe it's 10 or 12 gage.
Soldering and shrink wrap is preferred over a crimped connection when dealing w/something as critical as the ignition. If the splice fails- you are up the road w/o power. If you DO crimp it, still use shrink wrap and quality terminals installed w/a good crimping tool.
Old 07-17-2010, 06:49 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Is the coil a stand alone, meaning on the fire wall? Look at the coil, it is marked + or - , If I were doing it I would interrupt the NEG - side. This would require you to run both wires from your kill switch out to the coil. Remove the NEG - wire, cut the terminal off and solder one of the kill switches wires to that. Then the other kill switch wire, install a terminal like the one you remove above, and attach it to the coil NEG - pole on the coil, your done.
Old 07-17-2010, 03:49 PM
A 76 Blazer would have an HEI distributor stock. Look at the cap - one of the wires is labeled "BATT" and the other "TACH". Splice a toggle switch into the BATT wire, turn it off to kill the ignition. This should take about five minutes.
kill switch with a self-resetting circuit breaker? garinhash Electrical 14 01-02-2010 12:03 PM
kill switch Scotto Electrical 6 12-02-2009 09:35 PM
electricially actuated kill switch that may be NHRA LEGAL?!? Scrumgees Electrical 5 07-15-2009 04:46 PM
Electronic battery kill switch Larry Day General Rodding Tech 3 10-11-2005 08:13 PM
My Kill switch is killing me! Pamzy Introduce Yourself 0 09-12-2004 02:52 PM
