Kinda general wheel question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2009, 01:07 AM
Modern_twist's Avatar
new pontiac owner
Last journal entry: start of teardown
Ok hopefully its cool to group these two together but I want to run radials on both a 40 pontiac deluxe 6 and a 48 plymouth special deluxe. I want to run radials on the stock rims can i do that or will there be an issue. I have heard some rumors that i cant run radials on the pontiac something about the rim buckling anyway i thought id ask.
Old 07-30-2009, 08:07 AM
Last journal entry: frame build
Can't imagine that radials would cause a wheel problem, but you are going to run into some alignment issues.
Old 07-30-2009, 08:56 AM
Wiki Edits: 31
they'll work fine.. but the old allignment angles won't work....
Old 08-01-2009, 01:15 AM
new pontiac owner
So about alignment
ok so i hate to admit this but i dont know alot about mechanics so when you say ill have alignment problems is this something an alignment shop could tune in for me?
Old 08-01-2009, 07:06 AM
SSedan64's Avatar
An Old School frame & alignment shop can. The average tire & alignment shop can't & wont.
Old 08-02-2009, 10:24 AM
Last journal entry: `63 fairlane
you'll also need to seal your stock rims with something like a spray-on
bed-liner material, just the middle part otherwise they leak a round the rivets. or you can run radial inner tubes, I use them with my old aluminium mags and have for about 10 yrs now.
Old 08-03-2009, 06:19 PM
javracer's Avatar
It's a Chrysler, not a Ford
The stock wheels were designed for tubes, so running a tubeless radial might not hold air, that's my opinion, somebody correct me if I'm wrong please, I can take it. If the stock wheels don't cut it try thus place, I've been thinking of these guys for my wheels on the `31.
http://www.truespoke.net/hotrod.html
Jim
TH350 general driving question rack Transmission - Rearend 5 04-18-2009 07:05 AM
Wheel Base Question. wishnevsky Hotrodding Basics 4 09-01-2008 08:23 PM
Question About Wheel Studs leejoy Transmission - Rearend 10 06-11-2008 11:11 PM
General Ignition System Question ourmartyr Electrical 1 03-06-2008 03:57 PM
wheel interchange question jackflash Suspension - Brakes - Steering 3 02-25-2007 11:13 PM
