King bearings should be OK for your intended use. The reason they are cheaper is they are usually made in India or Pakistan. I have seen some delamination problems (material pulled from backing) in a high horse nitrous car, but that may have been an isolated problem..
Doc here,
I have used King Bearings for years (Since the late 70's) and never had a problem. They have a plant just up the road from me in Cordellia Ca..and make ALL types of bearings.. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
I see, I did do a search before I posted and didn't find info I was looking for....but after I posted the similar threads thing found a post on them....It says that they have .001 extra clearance and causes lower oil pressure? that'll be ok?
I used almost all king bearings in my engine shop when i had it and had real good luck with them. Ran only king in my drag car at 520 hp and after a years use they where still good enough for any street motor. Would recommend them to anyone.
| king bearings | kiaserknife | Engine | 10 | 09-04-2007 08:20 PM |
| Loose King Pin | Doc68 | Suspension - Brakes - Steering | 3 | 05-25-2005 08:51 PM |
| Repacking Wheel Bearings? | oldschoolrods | Suspension - Brakes - Steering | 5 | 05-10-2004 06:37 AM |
| Can you check to see if camshaft bearings are still good in the engine? | firewood | Engine | 8 | 05-07-2003 02:27 AM |
| The King of Trid | Kevin45 | Hotrodders' Lounge | 3 | 12-09-2002 07:12 PM |
